ultramegabob
- Indiana
I have a customer that has a magnetic door release on a fire door on his building, It has 120 a.c. to the device (it is designed to work off of 120v.), but does not hold the door open, I checked for continuity on the coil of the device, it appears to be open, I am assuming that it is defective. normally I would have thought this would have been a low voltage d.c. circuit, How does the electromagnet in this work? does it have a built in diode that converts it to direct current to make the magnet work? Is doing a continuity test the proper way to troubleshoot this device? thanks....
