afried9499
WHEN INSTALLING AN AUTOMATIC OPTIONAL STANDBY GENERATOR IN A HOUSE, CAN THE HOME OWNER USE A 200 AMP TRANSFER SWITCH WITH A 15 OR 25 KW GENERATOR AND SHED LOAD AS NEEDED TO POWER THE ENTIRE HOUSE KNOWING HE MAY NOT BE ABLE TO RUN THE OVEN AT THE SAME TIME AS THE ELECTRIC BACK UP HEAT? IF THE HOME OWNERS KNOWS HE HAS THE OPTION OF RUNNING EVERYTHING IN THE HOUSE BUT NOT ALL AT THE SAME TIME, DOES THE CODE ALLOW US TO MAKE THE HOME OWNER HAPPY AND USE A 200 AMP TRANSFER SWITCH TO POWER THE ENTIRE HOUSE. THE CODE SAYS THAT IN ART.702 THAT HE MAY CHOOSE THE LOAD TO BE ON THE GENERATOR?
BALTIMORE COUNTY SAYS THIS IS AGAINST CODE. ARTICLE 702 IS SAYING THE OWNER CAN CHOOSE WHAT HE WANTS TO RUN AT ONE TIME. A GENERATOR IN A HOUSE IS CONCIDERED A OPTIONAL STANDBY SYSTEM AND NOT A CRITICAL OR LEAGAL STANDBY SYSTEM.
WHAT IS YOUR OPINION ON THIS?
ARNOLD FRIEDLANDER
{Moderator's Note: Edited to remove email address}
[ September 28, 2004, 08:13 PM: Message edited by: charlie b ]
ARNOLD FRIEDLANDER
