sceepe said:
All very fine explanations. How do you descibe an ATS with a closed transition back to utility power. Are both sources connected for a fraction of a second or are the perfectly sychronized and then the switch is thown in a fraction of a cycle? Also, don't they have ATS's with overlapping neutral pole?
I take it by "closed transition" you mean zero interruption of power on transfer back to "utility".
The smaller/residential ATSs I've worked with simply do a VERY FAST changeover (using some fairly substantial solenoids to rapidly move the contacts from "gen" -- thru "off" -- to "util") and transfer the entire load at-once. This happens fast enough that most residential type loads (including HVAC, computers, clocks, and TVs) keep on running. I suppose you
could implement a gen sync device -- or even auto-paralleling w/ a smooth load transfer. It's all about what the customer needs and how much he's willing to pay.
In the larger (multi-meg) multi generator setups I've delt with, while we had fully automatic paralleling and load transfer
within the plant ... we could parallel to "utility" only under
operator control and then, w/ procedures limiting parallel ops to only long enough to smoothly transfer the load (i.e. a few seconds). I don't know that this return-to-utility process isn't automated elsewhere (I'm almost sure that it IS given the number of generators backing-up remote unmanned sites -- and it's not technically difficult) ... I've just not personally worked with any of them.
Obviously the POCO gets a "vote" in any implementation involving parallel ops w/ the utility.
Re: your neutral question ... some ATSs
do switch the neutral (making the genset a separately-derived system) while others implement an unswitched neutral.
