Mr. Serious
- Oklahoma, USA
- Electrical Contractor
I've been putting this off far too long, because it seems complicated. I told a customer that I could quote a transfer switch for them, but I haven't ever bought or installed one before, so I have some very general questions.
I believe I am looking for a 200A service-rated outdoor transfer switch. NEMA 3R rating is fine. This will be mounted on the outside north wall of a house in far south Tulsa County, Oklahoma. The meter can will be on the outside of the wall too, and the main panel is already mounted on the inside of the wall
1. Do neutrals and grounds need to be separated within the main panel, and the bonding be done only within the transfer switch? I originally intended to do so, but the journeyman on the job didn't see the separate ground bar I had included and he wired the neutrals and grounds all together in the panel. It would be difficult to change now.
2. Searching for such a transfer switch, the first one I found was the ASCO Series 185SE, model 1AUSA2200F4M. I first looked at it in November and found a listed price of $1700, and I believe that's up to about $1800 now on the one vendor I found with a price listed. However, today I just found the Generac model RXSW200A3 listed for about $800 from three different vendors. Is the ASCO better quality, worth an extra $1000? Perhaps if I ask for a quote it would be a little cheaper than listed.
3. Also listed with the ASCO transfer switch was an acccessory, a heater that goes inside the box for cold weather. How necessary is it? I expect with the north-facing wall, this unit will be exposed to the full extent of the lowest temperatures we get around here, usually -10°F or greater, but we have had two recent winters with a few hours to a day of -20°F temperatures.
4. Recommend any other accessories to have, or features to look for.
