Any info on connecting a aux contact on elevator disconnect switch? Is this something you add to the disconnect? or do you have to purchase it installed on the switch?
Electrical interlocks for heavy duty 30?1200 A safety switches are available factory-installed or in kit form for field installation. Each kit contains instructions for proper field mounting. A pivot arm operates from switch mechanism, breaking the control circuit before the main switch blades break. Switches with electrical interlocks installed are UL Listed. For factory-installed electrical interlocks add E
I (for one contact) or EI2 (for two contacts) suffix to catalog number. See Supplemental Digest page 2-4 for electrical interlock contact ratings.
Table 3.21: Electrical Interlock Kit
a
Switch Rating (A) Series Number (See pages 3-14, 3-15) Electrical Interlock Kit Cat. No.
