codequestion
Banned
- MD, USA
I have incoming electric service into 1600a main service disconnect. Load side of the main service I have 8 disconnect which fed to 8 different tenants.
The service system ground and main bonding jumper is at 1600a main service disconnect.
Each of the 8 disconnects also have GEC bonded to equipment ground bus and to the two system service ground electrodes but there is no main bonding jumper.
Is the 8 disconnects valid auxiliary ground electrodes that does not use ground as effective ground fault path per NEC 250?
Sent from my SM-G935U using Tapatalk
