I'm putting in a couple of 45KVA transformers for some new machines.
The machine will only need about 50% of this KVA rating. I was thinking about adding a couple of receptacles off the transformer as well for all the auxillary equipment.
Its a 480 delta to 240 delta 3 phase.
I want to build a unistrut structure over the transformer or next to it to mount these receptacles to.
I would use a fused disconnect switch fed from the transformer and then to the receptacles. Would this be acceptable ?
If not any other similar alternatives would be greatly appreciated.
Thanks
Mike Miller
Thanks
Mike Miller
