mrkc949
- Richmond, VA
My question is from the following video : https://www.youtube.com/watch?v=YuDqXFvRv94
if you have two electrodes at two different points that are bonded together and when lighting strikes, because of the voltage gradient you will have 100's and 1000's of volts between these two points which is highly dangerous.
But doesn't the same thing apply where you have ground rod at one point and water pipes, building frames/concrete bars at a different point all bonded together ? Wont there be a huge potential between those two points ?
