wireman1
from the main distribution system . a feed going to a 480/277 panel with a 400 amp main this is a full rated system. the available fault current lets say is 40,000 amps. does the brakers which feed 277 volts for the office areas and 480 volts for hi bay lighting carry the same rating of the main breaker if is rated for 40.000 amps ques 2 what about a series rated system panel a 60,000 amps panel b 40,000 amps panel c 20,000 amps. would the manufacturer under engineered design specify what the rating of the breakers would have to be for each panel in the series rated system.to make it a safe operating system.
