If a 480V electrical panel is to have thermal imaging performed, it would require the panel cover to be removed, however, the calculated available fault current value exceeds the maximum PPE protection. Since the PPE is not adequate for the calculated energy level, the panel cover cannot be removed. Are there any options available other than not to perform the task?
On a similar note, if the same panel was de-energized and locked out for the purposes of performing work on a circuit, the panel is considered energized until proven it is in a zero energy state, thereby, requiring PPE to be worn until verified. If the PPE is insufficient protection for the calculated available fault current value, what other options are available to verify a zero energy state and not compromise the safety of the employee?
MV
MV
