Good morning all! I've used Mike Holt's Fault Current calculator several times and it works well for most applications. But there doesn't seem to be an option for overhead services with open-air conductors. Also, it asks for the size of wire and whether you're using aluminum or copper. Well, the size and type of wire used in the service mast is different than the wire that the POCO uses. Does that become a factor? Is there a calculator on-line that's available? Any help is appreciated. Thanks!
