ElectronDance
- SE Arizona
i am looking for a solution to a device mounting issue, kind of outside the box at this point and hoping someone has seen an answer I cannot find. I am working with Wheelock EMNA dual strobe/speaker units for MNS. Spec calls for a 4sq deep with an extension ring, device mounting holes match up to a standard 4sq configuration. Here's the issue I keep running into. The speaker unit has a 10oz magnet, rather large, and the footprint of the speaker unti is about 3 1/2". the terminals sit on the side of the speaker. So, you have to fit the loop wires (4 12g solid, 4 14g solid in our installations) into the terminals and turn them back in about 1/4" of space. This is leading to a lot of grounds on the system, as our installers are having trouble making things fit into a 4sq. without forcing the device and knicking the wire jackets (yes I know, more cautious installers would be the obvious answer, but I've got what I've got, and I'm a big fan of job simplification and idiot proofing anyways.)
So, my thought was to use 4 11/16" boxes and extension rings for the extra room. But, to accomplish this I would need some sort of flat plate adaptor to mount to a 4-11 and provide 4sq. configured threaded mounting holes. Been searching hard and haven't found such an animal, does one exist? I can make this work on ceiling mounted devices, as I can drill holes in the speaker mounting plate for the 4/11 box mounting and the plate is pre tapped for the device screws. Wall devices I need a different solution.
My other thought was 12 and 14 awg crimp style insulated 90 degree pin connectors. I know they exist, but have not been able to find a source for them.
Thanks for any and all help.
