Skunkel
- Grants Pass, OR
- Solar Contractor
Greetings, we have plenty of projects where we are installing 25kw/ nearly 100A of solar. We had an electrician, who was also an inspector, that is suggesting there is code allowing your to back feed tapped onto a sub panel feeder wires -if the wire is rated for 100A and protected by breakers on both sides. This is all run back to a 200 MSP.
Does anyone know how/ which code allows this?
Another nugget this guy came up with and installed was an inverter sum panel. Again a larger system with 2 Enphase combiners -nearly 100As, breaker fed into a sub panel w main 100A main breaker feeding directly into 200A panel with 100A feed in breaker on opposite end of main conductor/ breaker feed.
Looking for clarification, has anyone else done this?
Can you explain where in code this is explained?
