Do the same rules apply to the primary side of a transformer as the secondary when back feeding PV? Say you have a 208 volt panel that is back fed by a PV system. This panel is fed from a 30 kva transformer which is fed by a 50 amp breaker in some 480 volt switch gear. Does the 50 amp breaker need to be on the opposite end of the bus? Do you need to label the 480 volt side the same as you would the 208?
