Back to back outlet boxes in a stud wall.
I have read it as well. It is not in the NEC. I believe I read it in the instructions that come with the boxes. 3M makes a product that takes care of this. It is similar to Play-Do that you can mold on the rear of the boxes to seal the knock outs and wire penetrations.
I have never seen an electrical inspector pick this up, however I have seen the fire inspectors getting it.
Hope this helps.
The NEC does not totally ignore it. 300.21 FPN directs you to Building and Fire Codes for box penetrations in fire-rated walls,
