Sergio Vargas
I will need so advise to solve this problem.
In a project of a condo building, I have a situation where I have back to back receptacles on a demising wall. These boxes are located in two mirror image bath rooms and the outlets are in the same spot on both walls, considered back to back. The code does not allow back to back's and I will have to move one on either side or can I move it up.
Since I have a mirror on one side and a knee wall separating the vanity with the jacuzzi on the other, the only thing I could do is to raise the outlet.
Please advise if I should raise the outlet and by how much. :-?
Is there a minimum distance required on how far apart they need to be so that they are not considered being back to back and still comply with the receptacle required for the vanity.
