russ
- Burbank IL
Someone asked me about supplemental fusing on a fluorescent fixture, with whips containing wiring smaller than number 12.
I'm just checking to see if I'm right in answering that 402.5 and 240.4 allows smaller fixture wire to be connected to the circuit. I don't think whips are fixture wire, and would require supplemental fusing if undersized compared to the supply circuit.
Do you think that would also work (supplemental fusing) when use 14 to supply the fan and or lights in a bath room when using the 20 amp circuit.
