buckyswider
- Cold Point Hill, PA, USA
Hi all, in my avocation as a fire officer we've had occasional situations (yesterday being another) where trees/limbs (the usual culprit) cause a primary and neutral line on the pole secondary to contact one another, resulting in a charged neutral in a residence. By the time we get there the initial hazardous situation has self-mitigated, either by the transformer tripping or the tree continuing to fall and severing a wire. So when we get there we see charring in a panel, possible melted components in a panel, odors of burning from fixtures, etc.
I have a few questions regarding this. First, at times like these the POCO is usually swamped, and they're not on-scene to help/advise. Pretty much all we can do is make sure nothing's burning and check with a hot stick to make sure that the panel or nothing else is charged at that point. And tell the homeowner to get an electrician ASAP. Does it help to inform the POCO of our findings? By the time I cleared yesterday the POCO was out at the initial problem so I made my way over there to tell the lineman of our findings. The information didn't seem to be of much concern to him- I guess before re-energizing the secondary circuit they would have repaired and inspected everything anyway. Could re-energizing a residence after such a failure be hazardous? Not sure what all could be compromised in a panel with that fault. The POCO forbids us to pull meters anymore- but if I had my druthers I would've done that before leaving yesterday (in addition to opening the main breaker).
Secondly- is there not some kind of device that could prevent damage in this situation? Thinking about my own house now. I've seen this maybe a dozen times so far in my 21 years. You would think that it's a common enough occurrence to warrant some sort of prevention device, but I can't find anything at all that addresses this.
Thanks!
Thanks!
