Does anyone know if the NEC has verbiage for a warning sign for a switchboard that is backfed similarly to the verbiage it has for a disconnect switch? This is for a project where power is generated onsite and fed directly into the switchboard. The main breaker won't de-energize the bus, it just de-energizes the downstream panel. I believe the switchboard will still be service entrance rated because the G-N are bonded at the switchboard.
