Factory installed main breakers in stocked items are typically limited to 100, 125, 150, 200, 225 amps on your usual "loadcenters". Basic bus structures are 125 amp and 225 amp, sometimes 150 amp. Really small panels (2-6 slots) may have 40 or 70 amp bus.
If you want any other combination you need to get one with a bus equal or higher then your need and necessary breaker.
"convertible mains" panels may have wide variety of available main breakers, but you still mostly only find the ones mentioned above as the only that are already installed in stocked items.
Commercial panelboards - you usually order exactly what you want - could be factory assembled, or they may send you all the parts and you field assemble it.
