I am sure you misunderstood what he was saying. That said, if you were to disconnect one set, the 2nd board would still be energized from the other two sets, it just wouldn't have the ampacity of the third set available. If you took one set, disconnected it and hooked it up to a different source that might be what is referred to. But I don't call that backfeeding. Terms can be used differently, but I would merely call that an alternate temporary feed. For me, the term "backfeed" is to take a panel and instead of bring the power in to the bus connected main breaker, or main lugs, you install a breaker in a branch slot (or a terminal block made for this) and hook the feeder up to it.
