Therealcrt
- Kansas City
- Electrician
Is there anywhere in the NEC that says when it’s necessary to backfill underground conduits with gravel or AB3 or just straight dirt? I understand that when you’re under a road you should backfil your trench with gravel but what about under sidewalks or other cases? Is there an actual code that says weather or not gravel has to be used
