cosmicelectric
- Oceanside, CA
- Contractor
Hello all,
I am working on a project in a commercial building for my client who is in the sanitation chemicals industry.
The city, (Oceanside CA) requires that a ventilation exhaust fan be installed in the area chemicals will be stored.
The exhaust fan will be roof mounted, and is required to run 24 hours a day 7 days a week. The city also requires the fan have its own independent backup power system which must provide 2 hours backup power minimum in the event of an energy system shut down/power loss.
Specs of this exhaust fan are as follows:
Manufacturer: Loren Cook
Model: 120C15D
1/4 HP
Phases: 1
Volts: 115 @ 60hz
I plan to wire this on a dedicated 15A circuit.
I have worked with Generac backup power systems before, but have never been asked to provide a solution for something as small as this. I have installed backup power for server & technology systems as well, but those are fairly turn key.
Would anyone have any product / system recommendations that would provide a solution like this without being forced to install overly complicated /expensive equipment? Also, would an electrical device such as this require an emergency shutoff/disconnect switch?
Thanks in advance!
Model: 120C15D
1/4 HP
Phases: 1
Volts: 115 @ 60hz
Thanks in advance!
