LATTC Student
- SoCal
- Student
I was researching potential cost-effective off-grid backup PV solutions in the event of a long-term Disaster (recovery).
I currently have a 5KW AC-coupled (microinverter) setup with batteries: no backup, self-consumption only. Panels are JA Solar 355-JAM6(K)72-355/PR (Voc 47.5, Isc 9.69). It isn't cost effective for me to rollout the required switch/controller and MPU for a true whole home backup. What I want is a quick, off-grid, "backup" controller solution in the event of a major disaster . . . with a predicted prolonged service outage.
So I wanted to procure a solar charge controller/inverter that I could reconfigure and reconnect my existing solar panels to and then charge a battery bank.
Looking for most efficient recommended cost-effective configuration with an MPPT charge controller and PV array setup (Series/Parallel) and battery bank setup (12/24/48V). Maybe someone's personal preferences on a Solar Charge controller, inverter, or combo as well as most efficient design. I found the Outback Flexmax 80 FM80 MPPT 80 AMP Solar Charge Controller for ~$450 and it seems like a good purchase and I have a 12v 1KW inverter. Trying to minimize cost and leverage what I have. I also have a few MC4 combiner (parallel) connectors and some feeders as well as the battery cables for either series or parallel. Hoping to only expense the controller and or controller/inverter combo as this is designed for a disaster scenario only. Note, I do have a good 7K inverter generator but limited fuel storage capacity (~3-4 days max)
Thanks in advance
Thanks in advance
