I ran into a second bad GFCI receptacle in my house last week.
It started with a single trip that I believe happened during a thunderstorm. Then it started tripping more often, until it wouldn't stay on for more than a few hours.
It was the only receptacle on a 20A branch circuit, and it had my computer and printer plugged into it via 2 power strips. At first I thought it was a bad power strip. But after throwing one power strip in the trash, it still kept tripping.
Funny thing was it would often trip when I turned off a light switch that runs a couple of fluorescent lights. I had another bad GFCI receptacle that did the same thing when I turned off the lights. Neither receptacle was on the same circuit with the lights.
Anyhow, on both receptacles, the nuisance tripping quit after replacing the GFCI receptacle. I guess that's what I get for buying cheap receptacles. I think they were both an off brand.
So if you have trouble with nuisance tripping of a GFCI receptacle, and you can't find anything wrong, it might be worth a try to replace the receptacle.
