- Windsor, CO NEC: 2017
- Service Manager
I tend to tell stories with every bump in the road, so I'll keep this one short and sweet.
How critical is it to attempt to balance the loads on panelboards in a very large apartment building? Say, for example, there is a five story building, three floors of which contain 4 dwelling units a piece at the core. So, there are four feeders, supplying 3 panels apiece (feed through from floor to floor, vertically).
There are four additional wings, all supplied through their own 208Y/120v transformer, that fill out all five floors with dwelling units.
All five 208v transformers are supplied from the same 480v service.
Would you try to shift all the fixed appliances in each panelboard to different phases per floor? Would you shift the general purpose/lighting receptacles from floor to floor? Would you leave it to random chance for some items?
For this discussion, let's assume that the call is yours, and either the engineer has not specified a direction, or that you are the engineer, depending on what hat you normally wear.
