ball parky sort of blue vinyl or nylon insulated fork or ring terminal question...
MichaelGP3
San Francisco bay area
Fire Alarm Technician
Across different brands, the box indicates compatibility with 14 -16 gauge wire, but I've noticed that with more than one brand 12 gauge stranded fits and seem equally secure when crimped. Is this a big deal among electrical inspectors?
They make for a less congested look when used on .25" barrier terminal strips.
It's probably a listing violation to use it on wire that is not rated for size-wise 110.3 B.
If they are color coded for size, a sharp eye inspector may notice it and fail you.
I would try looking for other products or brands that have the compact size you want and are rated for the size wire you are using.
Like a lot of things that are probably perfectly safe to do it may well be a violation of the instructions that came with the listed device. Having said that some of the crimp on connectors people use aren't actually listed.
