This all doesn't make sense. A flouoresent fixture that has a ballast and utilize a double ended lamp requires a disconnecting means. One of those orange disconnect that Ideal makes. What is the whole intent of this disconnecting means. To protect the ballast or the lamp. I just installed 2 x 2 trophers, and the lamp that comes with the tropher is the "U" style lamp with the 4 pin connecting point. To me, all flouresent fixtures are double ended. no matter if it's a 1 point connection. Even the flourecent can lights that has the 4 pin connection should be concidered as a double ended lamp. It has a ballast on it. Well, these 2 X 2 trophers that we bought, didn't have a disconnect inside. We opted to install these disconnect in the fixture to make sure we passed inspection. Well, the inspector said we did not have to install the disconnects, because the lamps were not double ended!!!!!!
Even thought the supply house is covering the cost for us to install these disconnects, it was still a waste of time and money to do the extra work. Any thoughts if this inspector was wrong, or am I putting too much thought into this ine. I just don't want to option not to install it the next time, and inspector "B" will call me on it.
ANY Thoughts???
ANY Thoughts???
