alex6999
New member
- Toronto, ON
Hi.
I need to use germicidal lights in my appartment
I found PLT G36T8 48" at 1000bulbs
I also found Phillips G30T8 36", but I cannot find 3 feet fixture at reasonable price.
My choice T12 2 bulbs fixture with new ballast
1000bulbs answer about G36T8 only: The bulbs you selected run on a specialized ballast we do not carry on our website
Yes, they have only 32W ballast on their website.
36W 110V ballast not exists.... I think. I didnt found.
I can take 220V from stove, but prefer not to do it.
I found
http://www.lightingsupply.com/b232punvel-b.aspx
Universal Programmed Rapid Start FL Ballast for 1-2 F32T8 F40T8 F17T8 Lamps, Parallel Wiring Run at 120 - 277 Volt (B232PUNVEL-B)
This ballast able to run one 40W lamp or one or two 32W lamp.
May be stupid question, but will it run with one 36W bulb?
I going to run 1 bulb in bedroom and 3 bulbs(to cover by UV every corner and kitchen) in living room
I found
http://www.lightingsupply.com/b432punvhe-a.aspx
Universal Programmed Rapid Start High Electronic Fluorescent Ballast for (3-4) F32T8 F40T8 F17T8 Lamps - 120V-277V (B432PUNVHE-A)
It able to run 3 40W or 3-4 32W
I going to run 3 bulbs in different fixture from 1 ballast
Specs allow Remote Mounting: 20 ft. max. lead length, 18 AWG
Since 2 bulbs fixture cheaper than 1 bulb fixture, I thinking to install 2 bulbs, one germicidal and one regular F32T8
Its absolutly no reason to run this bulbs together.... so any way to run them from one ballast?
Probably not. I will install 2 programmed ballast to run 3 lights(each ballast)
and 1 instant start ballast to run 36W germicidal bulb. I will turn it on twice a week, so Rapid Start not a big issue.
I found this
https://www.ebay.com/itm/391344500038
Kelmar Electronic Ballast Model 240 for 1 or 2 F40T12 or F40T8 Un-Shunted Lamps 0.80A
Not sure againg if it will work with 36W bulb. Will it work?
and 1 ballast for F32T8.... so here is wide-wide selection
One more question.
T12 fixture usually have shunted or not-shunted sockets?
And will T8 bulbs fit?
For example this
https://www.ebay.com/itm/132385462449
Thanks
I found
I found
I found this
One more question.
For example this
Thanks
