- Tennessee NEC:2017
- Semi-Retired Electrician
I replaced a magnetic ballast with an electronic ballast today. The new ballast was an Advance RELB2S40SC. It is for either F40T12 or F34T12 and is a rapid start. After turning it back on the lamps lit fine, but about 2 or 3 minutes later I heard a noise and the lamps went off. I then smelled an electronic burnt odor so I turned everything off and opened up the light. The smell was definetly coming from the ballast. I checked all my wiring/connections and everything looked ok. I figured I just got a bad ballast so I went back to the SH and exchanged it.
Got back and put in the new(replacement) ballast. Double checked the wiring per the diagram on the ballast. Everything was correct so I turned power back on but I left the cover off to make sure everything worked before putting it back. The lamps lit and I left the cover off for a few minutes. They stayed lit so I turned off the switch, removed the lamps and put the cover back. Put the lamps back in, turned switch back on, lamps lit, everything fine.
I stayed around a while with the light still on to make sure before I left.
About 2 hours later, I get a call from the HO saying the light went off again. He said he heard something, maybe a hum, so he went to check and the lamps were not burning.
He said not to come back today but tomorrow maybe.
Question is what might be the problem with these ballasts? I wouldn't think I would get two defective ballast in a row. Anyone have any suggestions as to what might be happening or what to check? As I said, I've already checked the wiring and it is wired correctly. I didn't check the voltage because I didn't see a reason to, but I will check it tomorrow.
Any help would be appreciated!
