Hoyt said:Anyone have any idea what a small band needs for devices / power?
Without knowing, I'd suggest a 100a panel with a board for receptacles below it.Hoyt said:Anyone have any idea what a small band needs for devices / power?
iwire said:I used to work at place were we had small size shows a few times a week, we did fine with a about Ten 20 amp 120 volt receptacle circuits, a 100 amp 208 v 3 phase disconnect for sound power and 200 amp 208 v 3 phase for lights.
LarryFine said:Otherwise, I'd say a few MWBC's feeding 2-gang (or for 3-ph, 3-gang) duplexes.
LarryFine said:Well, there's small, and then there's small.![]()
fireryan said:Probably gonna catch hell for this but 1 50a 4 wire plug that they can plug there own panels into
Hoyt said:Wow... I guess I was thinking on the same lines as Fireryan....
This is a farily small bar and grill, I can't imagine a huge setup...but I guess that is why I am asking the questions...
It would have been interesting to watch an o'scope on the load end of that neutral.iwire said:FWIW stacks of cranked up amplifiers raise heck with the neutral of the feeders. (Well at least when someone had run a reduced neutral on this feeder.):grin:
LarryFine said:It would have been interesting to watch an o'scope on the load end of that neutral.
iwire said:I bet it would have been, I know that the neutral was actually vibrating, you could not see it but I could sure feel it.
That's either good advice or bad grammar.dbuckley said:Whatever you fit, dont fit a dryer socket with no neutral!
