sparkync
- North Carolina
I cannot find a reference exactly to "baptistry pools". I am assuming it would probably fall under the section for "Spas or Hot tubs". The main difference I see is the length of a cord on a "cord and plug connection". Normally it would be 3 ft. long, but 680.42 (2) (2011 code) puts it at 15ft. All the other requirements, GFCI protection, outlets 6ft. away from inside walls, switches 5 ft. from walls etc. I see. The job I am bidding has just a heating element with controls that sets down in the water. It is 240 volts (30 amps) and plugs into an outlet. Any other ideas on this?? Thanks
