Sure this has been answered many times but having difficulty finding a concise answer.
1) Simple 100A feeder from a residential main to subpanel installed in the same structure (actually I believe the main is probably classified as a sub based on the meter/disconnect configuration however this is probably irrelevant)
2) Running 4 wire feeder (#2's for HOT, HOT, Neutral and #6 for Ground) in PVC conduit
3) Understand the proper grounding and bonding procedures at the main and subpanel
Question: Can my #6 ground between the main and subpanel be a "bare" or must it be colored green insulation?
I've always understood that a bare was fine in conduit, however I'm hearing things that confuse me and can't quite determine from the code the exact answer. I'm in the USA, but maybe I'm hearing local codes or Canadian variations?
Thanks,
Steve..
Thanks,
Steve..
