baseboard heat with supply on right side and unit stat on left
HuntNJ
NJ
is it possible to do this with supply side on the right and unit stat on the left? I cant seem to find anything in any manuals
Absolutely. The element and the wire behind it form a loop.
Separate the wires at one end and insert the power.
Separate the wires at the other end and insert the T-stat.
Note that only a one-pole T-stat is needed/will work.*
A 2P will work, but only open the loop, effectively only one line.
By doing it this way does the T-stat satisfy the disconnecting means requirement?
The baseboards I sold, in the 70s, were rated for having the cables run the length of baseboard between the end sections. If using individual conductors you needed to run conduit between the sections.
