Is it allowed to have a dedicated 120V 20A circuit feed a permanent baseboard heater AND a single receptacle used for a wall-sleeeve A/C unit? The single receptacle is mounted in the wall to the side of the heater, not in an end cap. This situation occurs in several rooms, each having a single heater and single a/c recptable as part of that rooms "heat/air" circuit. The heaters are all 1250W or less at 120VAC. The air conditioners are all 12A or less. Everything is in conduit so it would be easy to run separate circuits, but there is simply no room in the 32/32 panel and I don't want to use non-ctl breakers in a new panel. A subpanel is an option, but is it needed for only 4 circuits?
Any advice or 2003/5 code ref. greatly appreciated.
