InspectorDan
- Chicago
don't have my code book handy , however it is a violation.Dear Sparkies,
Does the exposure of the interior of the J box and it's energized components to the MDF edges of the baseboard constitute a code violation and/or fire hazard?
Thanks,
Lowly Home Inspector
Yup. 314.20
In walls and ceilings constructed of wood or other combustible
surface material, boxes, plaster rings, extension
rings, or listed extenders shall be flush with the finished surface
or project therefrom.
-Hal
Yes it is a code violation.
Install an extension sleeve with longer 6/32 machine screws if needed to resolve the problem.
Keep tabs on the article and section and you'll know it next time. :thumbsup:Thanks everybody! I'm a bit ashamed I didn't have that information at my fingertips....
Thanks,Lowly Home Inspector
Home inspectors are not supposed to quote code. If they did this would give the customer the impression that this is a code inspection and it is not. All he needs to do is write up that electrical junction boxes are not flush with baseboard and suggest that a licensed electrician repair the problem ( we need to get paid to ). Or he can put the cover back on and petend he never saw this as a home inspection is non-intrusive. No reason for the receptacle cover plate to have been removed in the first place.Also it may be helpful to have a list of the common violations so you can put the sections on the red tag more easily
The only individuals who can tell me how to perform my home inspections are those connected with the Illinois Department of Financial and Professional Regulation. Other than that, I just let the opinions fall on deaf ears. I've been doing this long enough and with enough success that I am able to ignore peanut gallery comments. Thanks anyway!
I had missed the fact that Dan was an home inspector. I thought he was an electrical inspector however I see no reason why he couldn't cite code violations and give that info as long as it is accurate
Thanks Dennis.....I asked for a simple answer to a simple electrical question. I certainly appreciate any other advice folks may want to provide but I've been running my inspection biz for nearly 20 years and our company has done 20,000 inspections or more over that time. We know what we're doing. Just wanted to make that clear.....I'm here for electrical knowledge, as far as running a home inspection business well; I got that.
