basement receptacles on insulation board wall
T74
MA
I'm installing receptacles around a basement room with about 2" of foam insulation board already on the wall. Drywall will go over the insulation board.
Anybody done this?
I'm planning on mounting metal boxes to the foundation and running either romex or emt between them.
Anybody done this?
Foundation, as in the footer or floor of the basement? Or are you talking about the block wall behind the foam insulation board?
This install sounds like the way they do on pre-poured/cast walls. You usually have to cut a chase for the wires and cut out for the boxes.
Or is it the foam forms used for ICF?
As in the wall of the basement behind the insulation board
