Hello,
I have a very easy, basic electricity question related to ohms law.
How do you use the following example as a teaching tool related to ohms law?
The other day a coworker installed a used breaker in panel. It was given to him from a communications contractor that needed to feed a temporary circuit. Single pole, 20 amp breaker, 120 volts. (QO120)
The panel was feed from a three phase service.
Upon metering the lugs in the panel, the expected voltage was found. 110 volts, All phases to neutral, 208 phase to phase. Everything was as normal.
Upon testing the breaker, no load, (he tested it before he hooked up the branch circuit) ((smart)). He found that the load side of the breaker read 88 volts. It was determined that the breaker came from a Navy base and it had signs of corrosion and a white residue on the load side terminal connections. I would imagine the breaker had major corrosion on the internal over current components. Just a guess, as I have not had any experience with this issue yet. Navy yard and salt water?
He pulled out the breaker and did a resistance test. It read 7 ohms I do believe, but I might have heard him wrong. Anyhow, it was somewhere around that. This was from the point where the breaker clips onto the panel bus to the point where the wire terminations are. He was reading through all the internal components.
I got to thinking about it as it is related to ohms law, and wanted to prove out all the numbers.
He had a 22 volt drop when he metered the load side of the breaker. Wire terminal to neutral
Applied Voltage of 110 volts,
VD of 22
Resistance of 7 ohms through the breaker.
Can I prove out these numbers using ohms law? We don?t have a complete circuit; we just have a resistor in series with the voltage.
I can obviously find what my current would pull, E/R = I but but it still won?t help me prove out the Voltage drop.
Just in thinking about all things stupid, if you would have hooked the terminal of the breaker directly to the neutral bar, It would have created a 15 amp load through the breaker and could have proven ohms law if you would have used an amp clamp. This would just be a basic series circuit with one resistor.
I am just trying to nail down some basic electrical fundamentals as I feel like this is a perfect example to learn from. I can do the ohms law math very easy, but am having trouble applying it to case as it relates to the voltage drop of 22 volts. It is a lot easier for me to understand all the electrical theory aspects when you can put them into real life examples.
Thanks!
VD of 22
Thanks!
