- Bremerton, Washington
- Master Electrician
Use either 568A or B, but don't mix.
			That's kinda-sorta why I prefer using B; there's a visible (and easy to explain to someone) difference.I'm preferential to 568A for one reason: The wire pairings in the RJ-45 jack match that of RJ-12 phone jacks. If you plug in a 2-line phone, the pinout has Line 1 on WH/BL and Line 2 on WH/OR
I'm likely the only one goofy enough to buy a particular RJ-45 connector that lets the wires stick clear through. Leave them long, pull them up tight, the crimper cuts the wires off flush when it crimps the connector.I also trim and fan like you mentioned, but unless you hold tension on your wires to make sure they are bottomed out on the connector while crimping, most likely the green one will end up a little short
Well yeah, you can't let them go after you positioned them and cut them to length. You have to hold them as you slide them into the plug as long as you can till they are bottomed out.
Bought them from a local electrical supply house - leviton p/n as I recall. Slicker than sliced bread.
cf
The ANSI/TIA/EIA 570 Standard calls for residential to be 568A. Probably for that very reason.That's kinda-sorta why I prefer using B; there's a visible (and easy to explain to someone) difference.
cf
