A friend is building a new house. I have poured through the archives but couldn't find the answers to these questions directly (sorry if it bores you veterans). Certainly a certified electrician will perform the work so worry not.
Config is: pole mounted xfrmr, buried 200A, 120/240V service to meter base 250 ft away.
1) I would like to use (2) 2/0 copper conductors in parallel for each leg.
2) If I remark(tape) can I use green RHH wire?
3) what is recommended loss design point 5%?
