fncruz
- New Providence, NJ
Does EVERY component in a control panel need to be UL certified or listed for the panel to be UL508A certified?
Ul508a is a listing, not a certification.Does EVERY component in a control panel need to be UL certified or listed for the panel to be UL508A certified?
A fair number of the parts in supplement SA are not listed but rather recognized.There are a lot of different UL standards, the supplement that petersonra is referring to tells you what the specific requirements are to use something that is listed under a different standard:
UL 508A Supplement SA Specific Component Requirements
This document is intended to be used to determine the requirements for components when used in industrial control panels.www.ul.com
