Basis for Code Change
berglar
New member
MI
New to the forum, couldn't find this through a search.
We have a construction spec that uses as its basis the 1996 NEC Table 384-36. I currently only have a copy of the 2005 NEC and this appears to be Table 408.56. The numbers appear to have changed. Is there somewhere I can find the reason for the change to see if our spec needs to be revised? I work for a utility but I do not want to throw away the basis for our spec. Hopefully I will get my 2011 copy soon to check for further changes.
Thanks.
I don't have a '96 handy, but a '99 does not show any changes from '96 and '08
appears to be the same as 99 with metric numbers added.
