Bass Boat Electrical question
mlepori
New User
oregon
law enforcement
Hi,
I installed new lighting on all my compartments 2 years ago and ran wires through fuse panel i purchased. I would like to use the circuit breaker panel instead so it is a cleaner install and do away with the fuse panel. I cannot find any bus bars and am assuming that there must be some since all the old lights were at one time wired into circuits. Do you know where i might find them? I dont mind installing bus bars but if most bass boats have them already id rather use what should be there. Its a 2002 procraft bass boat if that helps. I have looked and cannot find any schematics on my boat online. Anyone have any advice? I would really appreciate any you may have.
Thanks,
Mike
This forum is on the NEC, boats and watercraft are not covered under the NEC scope. Its kind of a DIY post which we don't allow, so I will lock the post, and suggest you contact the boat mfg or go a marine supply company.
