mkgrady
- Massachusetts
I need to replace an existing bathroom exhaust fan. I won't have a chance to see it in advance. Does anybody recommend one that is a good retrofit model?
Is it a 70 CFM Broan or a Nutone QT series?I need to replace an existing bathroom exhaust fan. I won't have a chance to see it in advance. Does anybody recommend one that is a good retrofit model?
I won't retrofit a fan unless I see it in person first.
if you're looking for the easiest install, go to Home Depot and get a NuTone/Broan
The reason I say Home Depot is that they carry a lot of stuff that's geared toward DIY. that means it's more than likely going to be set up to retrofit from the in side of the fan
now, this won't get you the best fan but it will get you the easiest install
a couple of things to think about:
Some older fans did not mount on the side of the joist, using legs like a can light instead. Take a chunk of 2x6 with you in case you need to scab out a couple of times to get to the edge of the hole
When it comes to retrofitting a fan, larger is better. Not necessarily larger CFM but larger dimensions. The bigger hole will be much easier to work in
Size the CFM to the room. At least one CFM per square foot is my rule.
But be careful going over 100 CFM with a 4 inch duct. sometimes it will cause loud turbulence
No problem. I didn't see it earlier where you already said you picked out the NuTone ez80n. I've never used it but it probably won't get any easier than that.Thanks James. Good ideas
I looked it up on Amazon and one guy said he installed it in 30 minutes. I wouldn't bet on that though
No kiddin?I watched a video of a retrofit install. Looked real easy. Comes with ears like a plastic old work box
