Does the NEC allow connecting vent fans to lighting circuits? What if the fans are over 300 watts or 1/8 hp? I know that if you are running one 20 amp circuit to a single bath, you can include the fan, (unless it is a heater fan using over 10 amps). I nowadays run all bath, laundry fans on a separate circuit to avoid light dimming. I generally run a separate 12-2G to the range hood because it may become a MW unit in the future, but connect it to the 15 amp fan circuit. Typical MW hood = 1800 watts
