can the bathroom circuit feed other bath rooms? i know its a requierd 20a ckt but not sure if i can use same circuit for 2 bathrooms.
It depends, if you are feeding the receptacle only in one bath then you can feed the other bath with the same circuit. However, if you feed the entire bathroom with the 20 amp circuit then you cannot continue on to the other bathroom
You can feed a bath with one 20A circuit for lights and recpts and not anything else, or you can feed multiple bathroom recpts with one 20A circuit.
OK. what about a refridge, microwave, dishwasher, or anything in kitchen requiring GFCI in the kitchen would require a AFCI and GFCI protection at same time. BTW would the refridge outlet because of gfci and its own circuit need to be accessible? and not behind fridge. if sink is with in 6' Thanks
Whoa. Where are we? I thought we were in the bathroom.
Apparently we have moved into the Kitchen. I think the Garage is next.![]()
They use 15 amp circuits in the bathroom......in Canada.![]()
They have inside plumbing in Canada?![]()
Have a look at 210.11.
We are. But some people probably DO have fridges, micros and dishwashers in their bathrooms.
I think the building and/or health codes would not allow that. You can't even have a bathroom door into a kitchen anymore.
I'd love to see the actual code that prohibits it.
I am pretty sure I could come up with the code about the location of the doors, but I am also pretty sure you are talking about the appliances.
However, in order to stay with the OP subject, we probably can be assured there won't be any cooking facilities unless told otherwise.
