Plastic drain too, I presume.If I have a fiberglass bath tub and the water lines are plastic. and I drop a hair dryer in the tub with me and water the GFI will not trip ?
The only way you would have a path back to the metal water pipe is if the water is running, and even in that case I doubt that the GFCI would trip.If your water system is not a well then at some point the water will likely be in contact with a grounded metal water pipe. It would depend on the resistance of that connection to determine whether or not you would have the 4-6 ma needed to open the GFCI device.
The problem with your idea is that the only current flow will be from the hot wire to the neutral wire through the water, so that there will be no imbalance for the GFCI to sense.ok, I could be wrong about this as I have never actually dropped a hair dryer in a bucket of water on a hot/grounded conductor only GFCI protected circuit but I was taught that you needed only a hot/grounded conductor for a 120 volt GFCI. The way a GFCI operates is based on Faraday's law. The hot/grounded conductor are surrounded by a sensing coil, during normal operation the currents in the wires are in equal and opposite directions and of equal magnitude, there is no magnetic field surrounding the wires and the net magnetic flux in the sensing coil is zero. If the return current in the grounded conductor changes so that the two currents are not equal, circular magnetic field lines will exist around the pair of wires. This magnetic flux will induce an emf in the sensing coil and trigger the GFCI to trip before the current reaches a harmful level. So in my opinion it should work without a ground. If I learned this incorrectly, please let me know.
In that situation we have to assume a metal tub with metal drain piping. Or just note that it was only a movie.
Sent from my XT1080 using Tapatalk
