Bathroom exhaust
Jesse 63
San benito tx
I'm adding a new bathroom at my house trying to find out if I need to install an exaust fan. I have a window one of tha wall is outside perimeter of my house. Where can I find if nec shows if exaust fan is needed?
Heard that a fan is now required even if you have a window. Best pratice would be to purchase a ceiling fan that has a built in humidity sensor to turn it. on along with a timer wall switch. Read that fan should run from start of a shower or bath to 20 minutes afterwards to prevent mold growth especially in thight insulated houses. I' m looking in to have a motorised shuter open up to bring in fresh sir whenever a bathroom fan or gas furnance or gas dryer is running.
The motorized shutter is a great idea, prevents depressurizing the house. Better yet would be an air/air heat exchanger. My current house is much to leaking for that to work.
How much money we talking about?
Required or not I would install one if it were my house.
I roll my eyes when GC's mention "what about the window rule?" When they want to opt out.
I tell them do what ever the bleep you want it's a building code not electrical.
(y)
I recommend the preset timers (typically the Leviton brand) to my customers whenever I install a bathroom exhaust fan.
I put 60-min mechanical spring-wound timers on mine.
I like the humidistats, put one in my bathroom when it was gutted a few months ago, has a adjustable preset manual cycle which was set at 15 mins. & the auto cycle if it determines there is too much humidity, been pleased so far. Been better then a month since needed heat, & with a open window the fan is not needed as much.
The whole family likes to take long showers, and even with the window open water condenses on every surface. Plus, not a terrific option in the middle of January, at least not in NJ. If we ever redo the bathroom, a fan will definitely be on the list.
We need to start building bathrooms like they do in Japan... where every surface is waterproof and the whole room could be hosed down with a pressure washer.
