To build on what Charlie said (I'm not arguing, as I know he knows this), if there are two receptacles inside the same bathroom, then the circuit could supply lights and equipment inside the same bathroom.charlie b said:It's allowed so long as there are no loads other than bathroom receptacles (i.e., no lights, no fans, no receptacles outside bathrooms) on that same circuit.
normbac said:I always wire each bath outlet seperate from all others (dedicated) except on ocassion Ill load one bath to the guest bath if it is seperate from any bdrm area. (Basic powder room)Two hair dryers at the same time are probable, and @ 15 - 1800 watts each pop goes the gfi (Then comes the questions from the unhappy homeowner)
And thats the bottom line.stickboy1375 said:If thats what the HO is willing to pay for then am all in!
georgestolz said:To build on what Charlie said (I'm not arguing, as I know he knows this), if there are two receptacles inside the same bathroom, then the circuit could supply lights and equipment inside the same bathroom.
You could supply the lights and fan first, and then hit the first GFCI, and then hit the second GFCI (all within the same bathroom) on the load side, if you so desired. If the circuit supplied receptacles in more than one bathroom, you would only be allowed to supply the receptacles, and the other outlets would have to be on a different circuit. (See 210.11(C)(3).)
If we were talking about one bathroom with two receptacles and lights and a fan, and you put the lights on the load side of the GFCI, that would be legal, but most would consider that a bad design from a usability standpoint. A cord-and-plug-connected appliance could trip the GFCI and leave the user in the dark.
JDaws said:We were having a shop discussion about the common practice of feeding a 20-amp bathroom GFCI in a residence and using the line/load feature to feed a second bathroom GFCI. Allowed? We have mixed opinions in the shop.
