Re: Bathroom GFI
Jmd445,
Is this the only bathroom in the dwelling? You said this was a remodel, so unless the wiring to the bathroom has been changed then the light is probably on the general lighting of the dwelling and that is probably a 15amp circuit. 210.11(C)(3) states: "In addition to the number of branch circuits required by other parts of this section, at least one 20-amp branch circuit shall be provided to supply bathroom receptacle outlets. Such circuits shall have no other outlets"
Now the exception to 210.11(C)(3) states: Where the 20-amp circuit supplies a single bathroom, outlets for other equipment within the same bathroom shall be permitted to be supplied in accordance with 210.23(A)(1) and (A)(2)
What all this boils down to is that IMO. If you have one bathroom and one 20-amp circuit feeding this bathroom then you can have the light and fan and GFCI on the same circuit. Anything else like two bathrooms, then the 20-amp circuit required by 210.11(C)(3) can only feed the receptacles and the lighting will be supplied by the general lighting of the dwelling.....But that is just an apprentice's opinion, wait and see what others with more experience have to say.....
If you are worried about your electrician then talk to him or her. We are generally all good people
[ October 03, 2005, 01:28 PM: Message edited by: kevinware ]
